The Modern Warfare 4 Season 1 Battle Pass puts the free Cronen Osprey at level 16 and the CSG 35 at level 36, alongside skins, blueprints, COD Points and XP tokens. Players considering CoD MW4 DMZ Leveling Boosting can use those milestones to plan their sessions around the rewards they actually want.
Which Modern Warfare 4 Season 1 pass should you choose
The free track lets you work toward the Cronen Osprey without buying a pass, while the standard pass costs 1,100 COD Points and the upgraded version costs 2,400 COD Points. BlackCell offers additional exclusive rewards, including operator variations and weapon variants.
Start by checking the rewards you want before spending points. If your main goal is a new weapon, the free track gives you a clear target at level 16; if you care about skins and blueprints too, compare the paid rewards with the amount of time you expect to play.
The standard pass also includes a 10% Battle Pass XP bonus and the Downpour Blitz operator skin. A catch-up system can grant progress after missed days, so you don't have to treat every missed session as a lost opportunity.
What does BlackCell include
BlackCell starts with the Operator Zero skin, the M4 Perimeter Lance blueprint, the Dog Food finishing move, a lobby scene, a casualty triage kit and 1,100 COD Points. Its extra operator variations also give you objectives to pursue after collecting those initial rewards.
The Cowed skin asks you to earn points through eliminations, while the Adder skin involves successful extractions. Point values differ by mode, so read each challenge in the game before deciding where to spend your next session.
That distinction matters when you're picking between a quick multiplayer run and an extraction attempt. Choose the objective that fits the matches you already enjoy, then check your progress afterward so you know what remains.
Which Modern Warfare 4 weapons should you unlock first
The Cronen Osprey is the first clear target for players who want a free weapon, arriving at Battle Pass level 16. The CSG 35 follows at level 36 and is presented as a return of the FMG-9.
Those milestones give you a straightforward way to pace the season. Aim for the Osprey first, try it in your usual loadout, and decide whether the push to the CSG 35 matches what you want to use next.
There are also blueprints for the Patriot XM4, Signal 50 and ISO Hemlock, with BlackCell alternatives for some weapon variants. Check which rewards suit your preferred weapons rather than treating every cosmetic as an equal priority.
How can you make steady progress across modes
Pair Battle Pass play with camouflage objectives that suit your chosen mode. Assault rifle tasks include double kills in multiplayer, triple kills during extraction matches, or eliminations with ground-loot assault rifles in Warzone.
Other categories ask for different results, including close-range SMG kills, sniper headshots and melee eliminations. Pick one category before you queue and bring a suitable weapon, so your normal matches also contribute to an unlock you're actively pursuing.
Use XP tokens when you've got time for several matches, and keep extraction objectives in mind if you're working toward Adder. Check the exact challenge text before each session: a task that suits one mode may call for a different action in another.
Set your next target around the reward you'll use most, then check your current level and challenge progress before playing. You can also explore CoD MW4 Bot Lobbies for sale as a possible next step, while reviewing the game rules and service details for account and gameplay risks.
Unlock Season 1 Rewards in Modern Warfare 4 with U4GM
CrystalVibe
- Uusi jäsen
