The September 30 Advanced Access launch gives AION 2 players a reason to prepare their systems before logging in. Installing the client is the obvious first step, but NVIDIA users also have several graphics options worth checking. If you are planning your early progression and following Aion 2 Items, having a stable frame rate can make the first few sessions much more comfortable.
AION 2 is built with Unreal Engine 5 and includes large environments, flying, combat effects, and situations where many objects can be visible at once. That means a graphics setup that works well in a quiet location may not perform the same way during a crowded encounter. Players tracking Aion 2 Items should therefore spend a little time preparing their hardware and graphics settings rather than waiting until launch day.
Pre-Install Before September 30
The pre-download period began September 28. If you have access to Advanced Access, there is little reason to wait until September 30 to install the game.
The PURPLE Launcher is the recommended PC option. Install the latest PURPLE software, open the Aion 2 section, and select Pre-install.
Steam provides another option. Search for AION 2 through the Steam Store and start the pre-download from the game page.
Downloading before launch also gives you an opportunity to check whether your storage drive has enough free space and whether the installation completes correctly. Discovering a storage problem five minutes before servers open is exactly the sort of issue that can be avoided with a little preparation.
Remember that Founder's Pack ownership is required for the September 30 Advanced Access period.
Install the Latest NVIDIA Driver
Once the game client is ready, move on to the graphics driver.
NVIDIA has released a Game Ready Driver specifically supporting AION 2. Open the NVIDIA App and select Drivers. If a newer Game Ready Driver is available, install it before launch.
A restart afterward is recommended. It also gives you a good opportunity to close unnecessary background applications before your first session.
If your PC uses a non-NVIDIA GPU, you should still check for the latest driver from your hardware manufacturer, although the DLSS 4.5 features discussed here are designed for compatible NVIDIA GeForce hardware.
Turn On Experimental NVIDIA Features
Players who want to experiment with the newest DLSS Transformer models need to check the NVIDIA App settings.
Open Settings and select About. Look for the option that allows access to beta or experimental features. Enable it if you need the option for DLSS Override.
Next, open Graphics and select AION 2. Find the DLSS Override section and change it from "Use 3D App" to Custom.
This gives you control over the available preset instead of simply accepting the game's default driver configuration.
Start With Preset M
Preset M is the logical place to begin for a normal gaming setup. It is intended as a balanced option, so it makes more sense as a first test than immediately choosing the most aggressive configuration.
Preset L is aimed at Ultra Performance mode. That can be useful when a system needs stronger upscaling to maintain a playable frame rate at a demanding resolution.
The important point is that DLSS should be treated as a tool rather than a setting that every player needs to maximize. Your monitor resolution and GPU determine what makes sense.
After AION 2 launches, open the game's Graphics menu and select DLSS in the relevant anti-aliasing or upscaling option. Then test the result during normal gameplay.
1440p and 4K Need More Attention
The recommended RTX 2070-class hardware provides a useful reference point, but it should not be interpreted as a guarantee of high settings at 1440p or 4K.
At 1440p, DLSS can reduce the amount of work required to render each frame while retaining much of the visual detail. At 4K, the performance difference can become even more important.
Multi Frame Generation is another option for compatible hardware. It can raise the displayed frame rate, but players should still pay attention to the game's underlying performance and responsiveness.
If the game already feels smooth, there is little reason to chase an enormous FPS number at the expense of image quality.
Check Real Gameplay Performance
Your final settings should be based on actual gameplay rather than a single quiet location.
Try moving through crowded areas, flying through detailed environments, and entering combat where numerous effects are visible. These situations provide a better idea of how your system will behave during regular play.
If GPU usage stays near its limit, reducing some graphics settings or using a stronger DLSS mode may help. If the GPU has plenty of unused capacity while frame rates still fall during crowded scenes, the limitation may involve CPU or game-engine workload instead.
Final Launch Preparation
The best preparation is fairly simple: preload the client, update your driver, enable the NVIDIA App options you actually need, and verify DLSS inside the game after launch. If you later decide that you need additional resources for progression, looking into Aion 2 Kinah for sale can be a separate consideration, but it should not distract from making sure the game itself is running properly.
Optimizing Aion 2 DLSS 4.5 Settings Before U4N Advanced Access
JackWalker
- Uusi jäsen
- Kotisivu: china
