U4GM on PoE Legion Farming: Is Your Build Ready
luissuraez798
Viesti Kirjoittaja luissuraez798 »
A PoE Legion build is ready for sustained farming when it combines broad coverage, reliable damage against durable targets, and stable recovery while surrounded. Ordinary map clear speed alone does not prove readiness for stacked encounters. Spending more on POE currency cannot replace coverage or survival.
Judge Readiness Before Adding More Encounters
Start with Legion alone when your character clears ordinary maps comfortably but has not yet handled repeated, demanding encounters. Add Bestiary or Abyss only after the primary farm runs consistently. Combining all three immediately increases costs while making the cause of slow or failed maps harder to identify.
Threads of Creation add their associated encounters through the Map Device, so they determine which supported content you actually run. Shaped Regions provide free Threads, reducing the paid inputs required for a matching route. Atlas passive investment supports those encounters but does not replace encounter access.
Readiness check Proceed when Reduce investment when
Coverage Your attacks reach broadly across encounters Repeated repositioning slows completion
Focused damage Durable targets fall promptly Individual enemies repeatedly stall the map
Recovery You remain stable while surrounded Ordinary maps already exhaust defensive resources
Funding Realized sales cover another batch Unsold items account for most apparent earnings
Use a connected Atlas route toward Legion rather than splitting early points evenly across several mechanics. Finish useful reward clusters before purchasing supporting encounters. Keep an affordable mapping setup available while equipment catches up with the harder version.
Prepare a Controlled Thread Test
Test three Threads before six, then compare six against eight using consistent map preparation. Legion gains one additional encounter at three Threads, two at six, and three at eight. These are additional encounters, not the total number in the map.
Random modifier thresholds follow a separate schedule: one to three Threads guarantee at least one random modifier, four to seven guarantee two, and eight or more guarantee three. Moving between counts can therefore change more than encounter quantity. Higher investment needs a complete batch comparison, not a judgment based on one rewarding map.
On the Atlas, inspect the Shaped Region affecting the map you intend to run. Account for its free Threads before paying for more content.
Inspect the map item and reject modifiers your character cannot complete. Keep layout and preparation consistent across the comparison.
At the Map Device, configure the intended Thread setup. Check the displayed map setup against your chosen mechanic before activation.
Run the lower-count batch first. Record completion time, deaths, recovery interruptions, and rewards intended for sale.
Increase only the Legion Thread count for the next comparison. Leave supporting mechanics unchanged so the result remains useful.
Return to the previous successful count when additional rewards fail to cover the added inputs and time.
Confirm the setup through both the displayed configuration and the encounters that appear inside the map. When Legion is missing, check applied Threads and the regional effect before changing passive allocations. The ten primary Thread mechanics no longer appear randomly in ordinary map areas.
Check Unwavering Vision before planning a mixed farm. This keystone restricts maps to one Thread type, permits two Threads beyond the ordinary cap, and gives found Threads a 75% chance to become Gold. That restriction conflicts with combining Legion, Bestiary, and Abyss.
Count Selling Time Before Calling the Farm Profitable
Measure realized returns across preparation, mapping, sorting, and selling rather than counting everything in storage at optimistic prices. Subtract map purchases, rolling materials, paid Threads, and other consumables using one currency unit. Divide the remaining value by the full session time.
A hypothetical batch returning 600 Chaos Orbs against 200 Chaos Orbs of inputs leaves 400 Chaos Orbs before other costs. Across two hours of total work, that equals 200 Chaos Orbs per hour. Keep exceptional drops separate so one unusual sale does not conceal weak routine returns.
Track net experience across the same batch when leveling matters. More monsters are not an improvement when deaths erase the gain. Reserve another batch's input cost before spending surplus on equipment or additional encounters.
Prepare your next small Legion batch, verify its regional Threads at the Atlas and its configuration at the Map Device, then record costs and completion time. Before considering Path of exile currency for sale, identify whether coverage, recovery, or paid inputs actually limit the farm, and change only that factor for the next comparison.
