Do you have any tools which focus specifically on audio extraction?
boostbysocial
- Uusi jäsen
- Kotisivu: https://boostbysocial.com/
Yes, a dedicated youtube mp3 downloader has only one objective to pull out audio only, so this is likely to be quicker than common converters. You won't be overwhelmed with options on video formats that you don't need. If you're looking for something simple, look no further than Boostbysocial! It's particularly good to save podcasts or music you stumble on while browsing. Just make sure the sound quality setting is correct before downloading, as some programs will set the default to lower quality or rates if it's not changed.
